How to configure F5 in hybrid mode..?
Hello,
we already deployed F5 LTM in NAT mode. As per new requirement we need to make some applications in hybrid/route mode. So we can choose either SNAT or Route mode depends on the application requirement.
Hi, If I understood you, depending on the application type, you could create an iRule or LTM policy rules to set up the SNAT to automap or pool (one-arm network) otherwise keep SNAT to none when in a routed mode (two-arm network). e.g. http application where you consider forwarding and balance by http hostname. Is that what you need? It’s clear for you? Respectfully,
