How to configure CRL in F5
HI,
I have uploaded CRL file in /config/ssl/ssl.crl directory, now how to configure this file in client profile.
Kindly help me on this
Regards, Midhun P.K
Firstly, I don’t think that’s the right place anymore. I’d suggest you remove that file and use the configuration utility to upload it: System > File Management.
Once uploaded I believe you specify the CRL in a ClientSSL profile as necessary based on your needs. If you’re on v11 but not v11.4 do note this issue: 404 Page not found | BIG-IP Documentation
