How to configure 2 F5 LTM VE in HA mode
Hi everyone, I have to configure in HA mode 2 F5 LTM virtual edition (VE) version 12.1.2. This is an installation, not a migration. I would be very grateful if anyone could send the guide to accomplish this task. I have experience in configuring an F5 LTM VE (you know: config, setup), but not in configuring HA. By the way, the Hypervisor is RedHat KVM. Many thanks.
So many articles are available on dev Central. link
link2
Thanks for your quick answer. But link2 is not for virtual edition, ins’t it? Regarding link, I am not sure about the necessity of configuring HA groups.
Do you think these steps will work? 1) System->Platform tab 1.1) instead of “single device” pick “redundant pair” 1.2) set ID 1 for one VE and ID 2 for the other. 2) System->High Availability->Network Failover tab: 2.1) Check Enabled for Network Failover. 2.2) Put in the mgmt address of each other’s peer.
Regards.
