how to configsync overwrite use tmsh?
hi :
  • I checked the sync command from ask.f5.com -run /cm config-sync to-group Syncfailover
  • Can this command overwrite standby configuration?
No. In order to override full config from active to standby use below command. .
tmsh run /cm config-sync force-full-load-push to-group <group name>
hi ,bro :
bigip-v11.6.2 do not have this command.
modify cm device-group <dg name> devices modify { <device name> { set-sync-leader } } ,this is v11 .x through v12 .
K13887: Forcing a BIG-IP device group member to initiate a ConfigSync operation
whichever device you are one (standby in your case), you just run run cm config-sync force-full-load-push to-group <group name> this will set the sync leader and force the device to initiate the configsync process (doing a full sync)
