How to close client connection when server closed connection
I am developing a upload service,And I use the f5 Load balance. The upload server will check the upload is correct. If server find some error in upload stream, Server should close the connection.
I can close the underlying socket between the server and f5. But I cannot close the connection between f5 and client.
I tried to use the irule like
SERVER_CLOSED
clientside
{ reject }
but no effect.
How can i do this?
Very thanks!
Hi coolzyt,
Try this and see if it works for you:
log local0. "Client IP Address:  [IP::client_addr]."
when LB_SELECTED {
log local0. "Load Balanced Server:  [LB::server addr]"
when SERVER_CLOSED {
log local0. "Server Connection Closed to [IP::server_addr]."
TCP::close
log local0. "TCP Connection Closed to [IP::client_addr]."
Thank you Michael!
I have solved it. The server must use the RST packet to closed the connection,And f5 can close client connection now!
The only confused thing is the RST won’t trigger SERVER_CLOSED event.Anyway, It works!
