I need an example on how to clear RAM Cache using iControl in C. It should accomplish something like this: TMSH command “delete ltm profile ramcache profilename”
Any help is greatly appreciated.
Hi Renso,
Which LTM version are you running?
You should be able to use the methods under LocalLB :: RAMCacheInformation for this: DevCentral - An F5 Technical Community
Aaron
