Hello everyone: How can I check the memory utilization?
You can use usin cli:
tmsh show sys memory
at the end you can see total memory used (you can also see memory used by service/module)
Sys::TMM Memory (bytes)
TMM: 0.0
Total 3.3G
Used 650.4M
For more info:
You can also check memory usage using dashoard (on menu click on statistics then dashboard):
regards
