Am using LTM ver 10.2.4 i have a VIP which is natted with a Global Ip on the FW , for some reason f5 is not proocessing requests from the Gloabl IP . How can i check for conenction logs on the virtual Ip
connection logs as such don’t really exist. you can check the statistics to see if traffic hits the VS.
next step would probably be tcpdump on the big-ip to see what hits and what doesn’t.
can you give me the syntax for that
