Hi All,
I have created and deployed a VCMP guest on of our Viprion Hosts. The guest is configured in bridged mode, so the management IP address of the guest will be in same network as that of my host. I have configured my guest with all the appropriate vlan and network details.
Current management IP address of the Guest - 10.213.255.162
I was asked to change the management IP address to 10.213.255.163.. Please let me know how to do it? Can I change it from my Host ? on my Host ----> vcmp guest list ---> select the guest ---> change the IP address and then click on update.
Or change it directly on the Guest itself. Guest ---> system ---> platform ----> change the IP address and then click on update.
Please let me know the best way to do it.
thanks
