How to change default external gateway
Hi all, sorry but I just did something wrong.
On the F5 LTM VE, I change the external default gateway and I lost connection to the GUI. From the F5 VM console, how do I use command based to change it back ?
Assuming you mean management routes:
View management routes: tmsh list /sys management-route
Create management route: create /sys management-route default gateway 192.168.1.254
