How to capture SAML attributes
I am trying to set up an application that is using the F5 as a SP. Then I need to take the SAML attributes and create a cookie. I need to capture the SAML attributes so that I can make the cookie, how would I capture this information?
Try something like below in an irule
set user [ACCESS::session data get “session.saml.last.name.user”]
last.name.user might be different depending on your IdP(look in session details).
You can try with that → myF5
Here is some additinal information that might help → Session Variables
