Using V.10.2.4, VS configured with no persistence profile and using SNAT. How can I capture the server side traffic corresponding to a specific Client IP when using SNAT ? I’ve read that there are some extra tcpdump features in newer versions but am stuck on 10.2.4 for the moment. Do I need an iRule ?
The -p flag was introduced in 11.2 (I believe) to enable capturing peer flows. Prior to that it’s a bit tricky. Please review the following for more information on pre-11.2 options:
sol11555: Gathering data in preparation for a traffic impacting change to the BIG-IP system
Here’s an interesting thread that describes the peer flow option in 11.2:
in case you want to try wireshark plugin.
F5 Wireshark Plugin
plugin file
