Thanks for your answers.
I wrote an IRule which sanitize the Referer, only for requests wich come from other previous websites, only if domain host request is different than referer domain host.
With this type of sanitiez system, my application mechanismes are not impacted.
This is my IRule for communauty if it can helps someone…
Thanks for all !
if { [HTTP::header exists “Referer”] } {
Init
set sep “/”
set sep2 “:”
Referer
set received_referer [HTTP::header “Referer”]
set received_referer_splited [split $received_referer $sep]
set received_referer_domain [lindex $received_referer_splited 2]
set received_referer_domain_splited [split $received_referer_domain $sep2]
set received_referer_domain_splited_without_port [lindex $received_referer_domain_splited 0]
Domain
set requested_host_domain [HTTP::host]
set requested_host_domain_splited [split $requested_host_domain $sep2]
set requested_host_domain_splited_without_port [lindex $requested_host_domain_splited 0]
Compare if it is an external from
if { [string compare -nocase $received_referer_domain_splited_without_port $requested_host_domain_splited_without_port] != 0 } {
Differents → Sanitize requested
set sanitized_referer [lindex $received_referer_splited 0]$sep[lindex $received_referer_splited 1]$sep[lindex $received_referer_splited 2]$sep
HTTP::header replace “Referer” $sanitized_referer
log “Different ($received_referer_domain_splited_without_port<>$requested_host_domain_splited_without_port) >> Referer updated($received_referer->$sanitized_referer)”
OK
log “Equivalent($received_referer_domain_splited_without_port==$requested_host_domain_splited_without_port) >> Referer as is ($received_referer)”
