Hi everyone,
We are currently working on a traffic management requirement and would appreciate your input.
Requirement:
We want to implement a mechanism that blocks a source IP for 24 hours once it exceeds 5 TPS (Transactions Per Second). Even if the TPS drops later, the IP should remain blocked for the full 24-hour duration.
Current Setup:
- SSL Proxy (Client and Server SSL enabled) - Frontend and Backend both on port 443
- There are no other irules being used
- We are using a DoS profile on the F5, which blocks traffic based on a 5 TPS threshold.
- However, this blocking is dynamic — once the TPS drops below the threshold, the IP is allowed again.
- This behavior does not meet our requirement, as we want to enforce a fixed penalty (24-hour block) regardless of subsequent traffic rate.
What We’re Looking For:
A solution where:
- Once an IP exceeds 5 TPS, it gets blocked for 24 hours.
- Even if TPS drops below the threshold, the IP should not be allowed again until the full block duration expires.
iRule Attempt:
We tried using the below iRule to achieve this:
when RULE_INIT {
set static::TPS_LIMIT 5
set static::BLOCK_DURATION 86400 ;# 24 hours in seconds
set src_ip [IP::client_addr]
# If IP is already blocked, drop request
if {[table lookup -notouch “blocked_$src_ip”] ne “”} {
log local0. “Blocked IP $src_ip due to TPS violation”
drop
return
# Track TPS per IP
set count [table incr “tps_$src_ip”]
table timeout “tps_$src_ip” 1
if {$count > $static::TPS_LIMIT} {
log local0. “TPS violation from $src_ip. Blocking for 24h.”
table set “blocked_$src_ip” 1 $static::BLOCK_DURATION
drop
The above iRule gives an error like “insecure connection”
Could the insecure connection error be related to trying to run this logic in the HTTP_REQUEST event on SSL traffic. and how to fix?
Is there a better way to achieve this via iRules, DoS profiles, or a combination?
Thanks in advance for your help!
