How do I apply source_addr session persistence for RADIUS servers in LTM. I created virtual server for port 1812 and 1813 using iApps and when I try to apply source_addr session persistence it LTM throws an error saying that I should modify it only via iApps. But I don’t see options for enabling it iApps. Please help
Go to iApps > Application Services > Applications >> Click on iApp >> go to properties>> disable strict updates.
Once you are done with above update go ahead and assign source based persistence at virtual server level.
Regards, Raghav
