how to add logging to irule
Hi everyone
i want to add logging for my irule, thank you
log local0. “ALERT! - IP [IP::client_addr] is using [SSL::profile]”
when CLIENT_ACCEPTED {
  switch [IP::client_addr] {
    10.222.56.10 {
      SSL::profile Web-Staging-NoClientCert
    default {
      SSL::profile Web-Staging-Client
Hi Mohanad,
SSL::profile does not return the profile name.
You can use this.
		10.222.56.10 {
			log local0. "ALERT! - IP [IP::client_addr] is using Web-Staging-NoClientCert"
		default {
			log local0. "ALERT! - IP [IP::client_addr] is using Web-Staging-Client"
Find here all about logging:
https://devcentral.f5.com/s/articles/the101-irules-101-logging-amp-comments
regards
