Could somebody tell me how to include ssl cert info into the following irule listed below.
when CLIENT_ACCEPTED {
set tmm_auth_ssl_ocsp_sid [AUTH::start pam default_ssl_ocsp]
when CLIENTSSL_CLIENTCERT {
AUTH::cert_credential $tmm_auth_ssl_ocsp_sid [SSL::cert 0]
AUTH::cert_issuer_credential $tmm_auth_ssl_ocsp_sid [SSL::cert issuer 0]
AUTH::authenticate $tmm_auth_ssl_ocsp_sid
SSL::handshake hold
set id [SSL::sessionid]
when AUTH_SUCCESS {
if {$tmm_auth_ssl_ocsp_sid eq [AUTH::last_event_session_id]} {
SSL::handshake resume
set Z “success”
session add ssl $id $Z
when AUTH_FAILURE {
set Z “redirect”
when AUTH_WANTCREDENTIAL {
reject
when AUTH_ERROR {
set Z “redirect”
set y [session lookup ssl $id]
log local0. “y is: $y”
if { $y contains “redirect” }{
HTTP::redirect “http://x.x.x.x”
Thank you,
Rob
