How to activate a software volume via Icontrol??
Hi, I can install and delete all modify via icontrol.. Cal any one say how to activate a software volume in bigip box via I control…
There is using iControl, however what you will have an issue with isninteracting with the license system unless your device has internet access. I will follow up with the icontrol reference when I get to a computer.
