How many parameters does a ASM policy generally learn?
I know there isn’t a fixed answer.
But the oracle ERP application I am trying to work with now shows me around 815 learned parameters. This app has multiple forms and is a used for registering users who are then given a login account. Lots of info like upto 4 addresses etc is being asked.
Is this normal or something very wrong is going on?
How many does it learn for other such big heavy applications?
I think this could be normal. For example, I just created a new policy with the template for SAP NetWeaver and it contains 97 different parameters. Depending on the size and complexity of the webapplication the list of parameters will grow.
You could also deploy for test a new policy using the SAP NetWeaver template, and compare parameters and settings. If they are more or less the same (format of names, etc), I’ll expect that 815 learned parameters for Oracle ERP is normal.
