How many LTM objects do you have to manage?
I am curious to find out how large our LTM environment is compared to others. We have six LTM pairs, and several of them have what I suspect is an outrageously-large number of objects. Our configuration presents me with challenges like naming standards and admin GUI performance. I was curious to find out how your environment stacks up against ours in terms of a few objects:
Env VIPs Pools bigip.conf (bytes)
1 201 179 89972
2 86 87 45426
3 1290 1034 907704
4 551 429 562899
5 1740 1927 1064404
6 75 60 70608
Env VIPs Pools
1 8 12
2 49 33
2 135 83
2 19 44
2 125 125
2 82 99
And here’s a script to get the information.
Initialize iControlSnapin
if ( (Get-PSSnapin | Where-Object { $_.Name -eq “iControlSnapIn”}) -eq $null ){
Add-PSSnapIn iControlSnapIn
Setup Credentials
$user = “user”
$pass = “password”
$bigipdict = @{“10.0.0.1” = “Myfirstloadbalancer”; “10.10.10.10” = “Mysecondloadbalancer”}
function main(){
$bigipdict.keys | ForEach-Object {
runQueries -bigipip $_ -bigipname $bigipdict.Get_Item($_)
function runQueries(){
Param(
$bigipip,
$bigipname
$virtualservers = 0
$pools = 0
$success = Initialize-F5.iControl -HostName $bigipip -Username $user -Password $pass;
$f5 = Get-F5.iControl
$f5partitions = $f5.ManagementPartition
$f5partitions.get_partition_list() | foreach-object {
$partition = $_.partition_name
$f5partitions.set_active_partition($partition)
$virtualservers += $f5.LocalLBVirtualServer.get_list().Count
$pools += ($f5.LocalLBPool.get_list()).Count
“$bigipname`t$virtualservers`t$pools”
main
And here’s a script to get the information:
Setup Credentials
$user = “user”
$pass = “password”
$Global:sumvar = “”
function main(){
Param(
$bigipip,
$bigipname
$virtualservers = 0
$pools = 0
main
Regarding naming conventions, what’s yours?
I’m using partitions to separate the config and make it more maintainable but I have some naming conventions as well.
VIPs are named with the dns-port, ie google.com-80
Pools are named with dns-port_pool, ie mail.google.com-80_pool
SSL profiles are named after DNS, ie google.com
That seems like a more reasonable environment to manage. We don’t use partitions since we are a single organization, and the LTMs are managed by a single team.
Similar to yours. We try to keep _ for VIPs and for Pools. But many times the architecture is more complex than that, so we need to tack on the port number for the pool names. We also use for SSL profiles.
ENVVIPsPools
1286211
2984970
3302214
4541558
54299
65067
Naming Standards:
vip.(2 Letter Location Code).(Environment - DEV, INT, UAT, CAP, PRD).(Application FQDN).(Service Name - HTTP, HTTPS, etc.)
pool.(2 Letter Location Code).(Environment - DEV, INT, UAT, CAP, PRD).(Application FQDN).(Service Port - 80, 443, etc.)
The naming conventions vary slightly between VIP and Pool, but still allows us to specify what belongs to what quickly. Having the Application FQDN included into the VIP and Pool Names also helps us to quickly filter or narrow down what we are specifically looking for when it comes to a specific application.
The methodology has worked extremely well for us.
