How F5 handle session ?
hi all
i’m new F5 , i’m facing with concurrent session and how f5 handle session .
my diagram network : server farm--------FW--------F5--------internet
(Fw and F5 run mode route)
on F5 , i had config virtual server for access services from internet come server farm , and after time then concurrent session on FW grow
this is one of many virtual server on F5:
admin@wip(Active)(/Common)(tmos) show running-config ltm virtual Web_VNPT
ltm virtual Web_VNPT {
destination 222.x.y.z:http
ip-protocol tcp
mask 255.255.255.255
pool Server_10.0.115.10_80
profiles {
tcp { }
vlans {
internet-vdc
vlans-enabled
how to F5 handle session ? pls help me
thanks all
Hung, sorry but I’m not sure I understand the question. Could you re-phrase it please?
hi
My mean is how the f5 process session access from internet come server inside ? when the session time out then F5 delete this session ?
at the moment when it work about time then concurrent session on FireWall behind F5 grow hight . It make slow system network .
pls help me
thank all
Ahhh, OK, I think I get you now, thanks. So, you have an issue with the server side connections remaining idle for too long?
So, the idle timeout is controlled by the TCP profile assigned to the Virtual Server. The default value is 300s/5mins which is fine in most cases. I’d suggest you create a custom profile with a lower timeout and assign it to the VS server-side only.
Enabling the OneConnect feature should also help to reduce the number of server-side connections as it will re-use them.
Hi
My F5 have many the virtual server , would you like tell me how to set onceConnect profile for all virtual server ? and if set then anything effect to system is working ?
many thanks
OK, I’d suggest you read up on the OneConnect profile settings here: 404 Page not found | BIG-IP Documentation. Create a custom OneConnect profile and apply it to each HTTP Virtual Server as required, default settings will probably be OK. I’d suggest you test first of course.
There is of course always a bit of RAM and CPU overhead but hopefully this will be minimal, if you can even spot it.
