Instead of load balancing two nodes, we would like to treat them as primary and secondary nodes and we want the requests to failover to secondary, only when primary is not available. This needs to be implemented on HTTP, FTP & TCP profiles!
Define priorities on each pool member per the configuration guide. Note that there is an active bug on priorities, check solution to make sure your configuration isn’t vulnerable:
Thank You, would this be a “fool proof” solution for failover only? I have set it to 1000:1 ratio, but would be more comfortable if there is an option to specify “backup” node?
Don’t confuse ratio with priority. Ratio means that the “backup” server will get every 1001th connection in a two server scenario with your numbers.
Consider this example from page 4-13 of the configuration manual:
pool my_pool {
lb_mode fastest
min active members 2
member 10.12.10.7:80 priority 1
member 10.12.10.8:80 priority 1
member 10.12.10.9:80 priority 1
member 10.12.10.4:80 priority 2
member 10.12.10.5:80 priority 2
member 10.12.10.6:80 priority 2
member 10.12.10.1:80 priority 3
member 10.12.10.2:80 priority 3
member 10.12.10.3:80 priority 3
Figure 4.1 Sample
The configuration shown in Figure 4.1 has three priority groups, 1, 2, and 3.
Connections are first distributed to all pool members with priority 1 (the
highest priority group). If fewer than two priority 1 members are available,
traffic is directed to the priority 2 members as well. If both the priority 1
group and the priority 2 group have fewer than two members available,
traffic is directed to the priority 3 group. The LTM system continuously
monitors the higher priority groups, and each time a higher priority group
once again has the minimum number of available members, the LTM
Experience and other documents imply that priorities increase as the priority number increases, i.e., members of the priority 1 group would have the lowest priority and those of the priority 3 group the highest, just the opposit of the above description.
