Does anyone know if there is a good way to dump the management connection table using TMSH? I know I can use “tmsh show /sys connection” to see all the connections on the switch ports, but is there a way to do this for the management port?
I don’t think it’s possible because the management port is processed differently. Accesses to it (ssh/http) are audited.
Can you clarify what you mean by audited, and why that means it wouldn’t be possible? I agree it might not be possible, but I’m hoping to know for sure. Since netstat can dump out connections to the management port, I would think it’s at least theoretically possible that TMSH could do the same (whether TMSH actually implements such functionality is another question).
TMSH itself cannot display mgmt interface connections. You can, however, run netstat from within tmsh like this:
(tmos) run util netstat
