How do we configure VIP for UDP port ?
Hi Team ,
How do we configure VIP for UDP services ? Where and how will be the configuration differ from TCP VIP ?
Regards , SK
Hello Sajan,
For UDP VS, you only need to add following profiles :
  • “Protocol” UDP
  • “Protocol Profile” (client) UDP (you can keep the default)* “Protocol Profile” (server) (use client profile)
Then it is similar to TCP.
Regards
Hi Sajan,
check this article: myF5
