I want to create SMTP and POP3 by putting the SSL certificate in the virtual server.
And do I have to activate SMTP profile as well?
Version is 10.2.4 HF4. How do you make it?
SMTP and POP3 don’t do SSL, are you not talking about POP3S or using STLS?
in any case you running 10.2.4 isn’t going to help. you really should look into upgrading as 10.2.4 is almost out of support.
you are probably now looking at an irule as below
where with 11 and 12 you can use the profiles to do this
