How do I renew expiring certificates on F5 devices using internal domain Certificate Authority services.
How do I renew expiring certificates on F5 devices using the internal domain Certificate Authority Services.
  1. Creating the CSR request file.
  2. Exporting & Converting PEM file to .cer or p12 format for CA services to create the new/renewed F5 device certificate.
  3. Importing & converting new or renewed certificate .cer or P12 format to PEM.
  4. Ensuring it is working properly.
  1. Not an F5 specific task, you can find instructions for this online.
  2. Not an F5 specific task, as well, but: 404 Page not found | BIG-IP Documentation
  3. See 2 above, as well as 404 Page not found | BIG-IP Documentation
  4. If you have specific problems with your SSL configuration, point them out.
