How do I reference an administrative partition from bash?
We recently deployed administrative partitions in several guests for the first time. I know, I know. It wasn’t my decision!
So I used to be able to collect information like this:
tmsh -q show ltm virtual > list.txt
I want to be able to do the same thing from bash per administrative partition.
Jlarger,
Each administration partition will have its own folder, the default is simply Common (as you may know already).
To run a query and include all administration partitions I believe you add the “recursive” switch at the end (before the output to file).
See if this works.
N
Do this →
For a single partition:
tmsh -q -c "cd / ; list ltm virtual" > list.txt
For all partitions:
tmsh -q -c "cd / ; list ltm virtual recursive" > list.txt
KR, Dario.
