How do I obtain client IP Address?
We’re trying to troubleshoot some issues with connections through one of our VS to web servers. The goal is to capture the possibly offending source/client IP address and then add that to the IIS logs on the servers themselves. My boss thinks this can be done via a cookie, but my searches so far indicate an iRule that creates a cookie to do this (DevCentral - An F5 Technical Community).
Does anyone know how to capture this information and log it to the servers themselves?
We’re using BIG-IP 9.4.2 Build 228.18 Final.
Thanks in advance for any help.
Diane
have you seen this?
sol4816: Using the X-Forwarded-For HTTP header to preserve the original client IP address for traffic translated by a SNAT
So, that solution doesn’t require any iApp or anything other than the rule? My boss dug something up about iApp.
i do not think you really need iapp.
So, we have both http and https VS objects. So I need to do both the steps for the profile and the irule for the x-forwarded, is that correct?
either http profile or irule.
Then we need to get the IIS ISAPI filter installed/configured on the web servers?
i am not familiar with iis. anyway, i believe iis administrator should know how to log x-forwarded-for header value. :slight_smile:
