How do I get the sys connection result in bigsuds
Hey,
How do I get the F5 LB sys connection by using bigsuds? For example, tmsh show sys connection.
Thanks!
Chao Lin
b.System.Connections.get_list()
be careful though, on a very active system this will be a very large payload. You can get just the details of an active connection as well with get_active_connection_v2 method.
