How can i use soapUI direct adding a pool
Hi Folks,
I am tring to use the soapUI (http://www.soapui.org/) add a pool with pool members, does anyone know how should i do change the following XML to add a pool by soap direct?
Thanks!
<soapenv:Envelope xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:soapenv=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:pool=“urn:iControl:LocalLB/Pool” xmlns:soapenc=“http://schemas.xmlsoap.org/soap/encoding/”>
<soapenv:Header/>
<soapenv:Body>
<pool:create soapenv:encodingStyle=“http://schemas.xmlsoap.org/soap/encoding/”>
<pool_names xsi:type=“urn:Common.StringSequence” soapenc:arrayType=“xsd:string[]” xmlns:urn=“urn:iControl”/>
<lb_methods xsi:type=“urn:LocalLB.LBMethodSequence” soapenc:arrayType=“urn:LocalLB.LBMethod[]” xmlns:urn=“urn:iControl”/>
<members xsi:type=“urn:Common.IPPortDefinitionSequenceSequence” soapenc:arrayType=“urn:Common.IPPortDefinitionSequence[]” xmlns:urn=“urn:iControl”/>
</pool:create>
</soapenv:Body>
</soapenv:Envelope>
I haven’t used soapUI before, so I’m not sure how the UI works. Your SOAP message is missing all of the parameter elements (they are all empty). Here’s the trace of a create call using perl’s SOAP::Lite for a pool named “foopool” with a lb method of “LB_METHOD_ROUND_ROBIN” and an initial member of “10.10.10.10:80”.
Hope this helps…
< ?xml version="1.0" encoding="UTF-8"?>
< soap:Envelope
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
    xmlns:xsd="http://www.w3.org/2001/XMLSchema"
    soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"
    xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  < soap:Body>
    < create xmlns="urn:iControl:LocalLB/Pool">
      < pool_names soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array">
        < item xsi:type="xsd:string">foopool< /item>
      < /pool_names>
      < lb_methods soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array">
        < item xsi:type="xsd:string">LB_METHOD_ROUND_ROBIN< /item>
      < /lb_methods>
      < members soapenc:arrayType="soapenc:Array[1]" xsi:type="soapenc:Array">
        < item soapenc:arrayType="xsd:anyType[1]" xsi:type="soapenc:Array">
          < item>
            < address xsi:type="xsd:string">10.10.10.10< /address>
            < port xsi:type="xsd:int">80< /port>
          < /item>
        < /item>
      < /members>
    < /create>
  < /soap:Body>
< /soap:Envelope>
-Joe
Thanks Joe, it works.
My code is copied from soapUI GUI after i imported the WSDL file into it, i have no idea to fill the info in to it, now i can learn from your code, that’s cool~
thanks again!
And here is my code, we can use SoapUI show iControl’s power directly.
<soapenv:Header/>
<soapenv:Body>
<pool_names xsi:type=“urn:Common.StringSequence” soapenc:arrayType=“xsd:string[]” xmlns:urn=“urn:iControl”>
<item>Pool1</item>
<item>Pool2</item>
<item>Pool3</item>
</pool_names>
<lb_methods xsi:type=“urn:LocalLB.LBMethodSequence” soapenc:arrayType=“urn:LocalLB.LBMethod[]” xmlns:urn=“urn:iControl”>
<item>LB_METHOD_LEAST_SESSIONS</item>
</lb_methods>
<members xsi:type=“urn:Common.IPPortDefinitionSequenceSequence” soapenc:arrayType=“urn:Common.IPPortDefinitionSequence[]” xmlns:urn=“urn:iControl”>
<item>
<item>
<address>10.10.10.10</address>
<port>80</port>
</item>
<item>
<address>10.10.10.11</address>
<port>80</port>
</item>
<item>
<address>10.10.10.12</address>
<port>80</port>
</item>
</item>
<item>
<item>
<port>80</port>
</item>
<item>
<port>80</port>
</item>
<item>
<port>80</port>
</item>
</item>
<item>
<item>
<port>80</port>
</item>
<item>
<port>80</port>
</item>
<item>
<port>80</port>
</item>
</item>
</members>
</pool:create>
</soapenv:Body>
</soapenv:Envelope>
