I have done something new in our production Environment to save public IP address like url server1.xyz.com and server2.xyz.com both will have same DNS entry and then following irule will take care of redirecting our different client connect to different POOLS like this
if { [HTTP::host] equals “server1.xyz.com” } { pool client1 return }
big-ip can not decrypt SSH traffic, on top of that ssh has no URI. You can create a vip per domain name and assign related pool for that.
host1.ssh.example - 1.2.3.4:22
host2.ssh.example - 1.2.3.5:22
etc.
As alternative, you can redirect to specific pool member based on src ip if every client requires its own pool.
One more thing. You can use forwarding VIP which no pool required and traffic will be sent to specific pool member. But in this case you need specify back-end server’s Ip address directly while accessing the back-end server.
