How can I reselect port after persistence and LB_SELECTED has selected a pool member?
I am trying to change the port that was selected during during persistence and LB decisions and then modify the destination port. I have tried several things with poor results. The below results in not being able to find the pool member, which I suspect is from no exact match on node/port combo. I have also tried using node but the port seems to be ignored. Any ideas? The general idea is to have one semi generic pool, and destination port be selected from based on URI mappings in a data-group.
ltm virtual myvirtual {
    destination 10.1.1.10:any
    ip-protocol tcp
    mask 255.255.255.255
    persist {
        my_universal_persist_profile {
            default yes
    pool mypool
    profiles {
        http { }
        tcp { }
    rules {
        my_port_rule
    snat automap
    translate-port disabled
    vlans-disabled
ltm rule my_persist_rule {
when RULE_INIT {
    set persist_timeout "60"
when HTTP_REQUEST priority 998 {
    LB::detach
    if { [HTTP::header exists "someheader"] } {
        set myheader [HTTP::header "someheader"]
        persist uie "$myheader" $persist_timeout
ltm rule my_port_rule {
    when LB_SELECTED {
         set server_port [class match -value "[HTTP::path]/" starts_with "node_ports"]
         if { "$server_port" ne "" } {
            LB::reselect pool [LB::server pool] member [LB::server addr] $server_port
    when LB_FAILED {
    log local0. "LB_FAILED"
ltm pool mypool {
    members {
        server1.mydomain.com:any {
            address 10.10.10.10
            session monitor-enabled
            state up
        server2.mydomain.com:any {
            address 10.10.10.11
            state up
        server3.mydomain.com:any {
            address 10.10.10.12
            state up
    monitor gateway_icmp
LB::reselect node [LB::server addr]
should work for you.
