How can I renew default.crt
I know default.crt is used in templates as a …well “default”. But the certificate has reached the end of its time and constantly is sending traps creating tickets. This is causing me issues with service assurance. Seems to be impossible to renew the certificate
Have you tried K13579 ?
What do you get from this:
openssl x509 -noout -text -in /config/ssl/ssl.crt/default.crt -modulus
Try
tmsh load /sys config partitions all
