How can I monitor the member's loopback Interface (and service) ,when i use ltm npath mode?
How can I monitor the member’s loopback port ,when i use ltm npath mode? ltm npath mode: 404 Page not found | BIG-IP Documentation
I may be wrong but loopback interface is essentially up all the time, right ?
You would monitor the members using the non-loopback address. In the example document that would be 10.1.1.11.
You can use a monitor with following parameters:
  • transparent : enabled (will send monitor to mac address of pool member)
  • address alias : loopback address (IP packet destination is loopback)
Stanislas
Should be, unless someone changes that. That is why you’d want to monitor it’s availability or more importantly, you want to monitor if actual service (http, smtp rtc) is running on the loopback interface.
