How can I list distributed applications using the Python SDK?
I am trying to get a list of distributed applications using the Python SDK. I can do this via REST/Postman by drilling down to /mgmt/tm/gtm/distributed-app.
However when I drill down to gtm using the Python SDK, there is no “distributed-app” class to call. I see the following…
{'_meta_data': {'container': , 'bigip': , 'icr_session': , 'icontrol_version': '', 'uri': 'https://beiglb1:443/mgmt/tm/gtm/', 'minimum_version': '11.5.0', 'allowed_commands': [], 'required_command_parameters': set(), 'exclusive_attributes': [], 'object_has_stats': True, 'minimum_additional_parameters': set(), 'allowed_lazy_attributes': [, , , , , , , , , ]}}
As you can see I can access my wide ips/pools, servers, data_centers, etc… from here just fine, but I cannot see my distributed apps. Any ideas on how to access them via Python SDK, or do I have to use REST?
Are your distributed applications running in containerised environments?
