Guys, In my case, there’s an application which has a specific character in its XML body.
For example, the XML file is:
123456789
How can I get the code "123456789" and use to enable the session persistent?
Thanks for your help!
Hi, you can create an irule to parse the response from your app and use extracted data (Username field) as record for session persistence.
hi guys: i hope can help you
when HTTP_REQUEST { set xml1 [getfield [HTTP::payload 0] “” 2] set xml2 [getfield $xml1 “” 1] if { $xml2 == “jjg” } { persist uie $xml2 1800 } }
