How can I apply packet filter on managment vlan of guest
I have setup in which guests of viprions are in bridge mode and I need to stop inter-guest communication using packet filter. Can someone guide me how can I apply packet filter on management VLAN or if you can suggest any better option to avoid inter-guest communication.
Thanks and regards Amit Grover
Packet filters do not apply to the management interface. I could not find any solution that states that, so I did a quick test and confirmed that.
You can apply filter to the SSH/HTTPS access, for example. For SSH just go to system/platform. For HTTPS, here is the solution:
Another option is to use AFM, as AFM rules can be applied to the management interface.
