Hi F5 community,
I am new to F5 and still learning the console. Few days ago I was asked to configure F5 to block all but few pages in a website. Our web link format is as follows:
http://example.company.com:7077/pls/apex/f?p=769:9:0::NO:3:N6_COUNTY
Static Portion always http://example.company.com:7077/pls/apex/f?p=
Application Number for example 769
A list of colon separated items
i. Application Page for example :9
ii. Application Parameters for example :0::NO:3:N6_COUNTY,P3_TYPE,P3_SORT:3,A,R
The requirement is to allow 6 applications(app numbers and everything to it's right in that URL) and block all requests. On F5, I am showing the URL as "/pls/apex/f" . I don't think I can achieve this by URL config. How can I get this working?
Thank you.
Hi Sharath413,
if { not ([HTTP::uri] starts_with "/pls/apex/f?p=") } {
drop
If you want to check entire uri, you can use regex.
Thank you so much for your comment. It is really helpful but I’m new to iRules and so wondering if I can do the same with ASM security profile instead?
Please advise.
You need to do next:
1) Create all allowed URLs on “Security ›› Application Security : URLs : Allowed URLs : Allowed HTTP URLs” page
2) Remove pure wildcard (*) URL (if exists)
3) Enable Alarm and Block for “Illegal URL” violation
Thanks, Ivan
