I need you to give me a confirmation on a doubt about memory usage on bigip system. It’s true that TMM memory refers to the traffic management module (LTM) only ?
If* i need to monitor the memory usage of GTM and AVR modules present in a vCMP guest, *which OIDs i must add to my monitoring tool in order to poll them and extract the information who i need?
I saw that the guest takes in consideration only TMM memory and the remaining memory is interpreted as Other Memory, is it possible that in this field resides the GTM and AVR modules?
Thanks in advance for the support
