hotfix upgrade GTM 11.6.1 Hotfix HF2 to EngHF ? staps please
upgrade GTM with engHF upgrade, kindly advise how can I do that
Sys::Version Main Package Product BIG-IP Version 11.6.1 Build 2.0.338 Edition Hotfix HF2
The engHF contains the HF2 bugs + ID 584583 that is related to the time it takes for the configuration to load
EngHF installation is the same as all other hot fixes installation!
Place the EHF in /shared/images
log into the LTM, ensure you are in TMOS
(tmos) show sys software
select the target partition (a non-active partition) or decide on a new partition
(tmos) install sys software hotfix volume
if you are installing to a new partition that does not exist
(tmos) install sys software hotfix volume create-volume
This will install the Base version iso and then install the EHF.
After the install is complete, you can activate the new partition from the webui, or use switchboot
