Problem this snippet solves:
This code is initially developed to provide a forward proxy to Apple Push Notification Services. This code can easily be customized to load balance requests to any resolved FQDN.
Several issues are solved here :
- Forward proxy for several Apple APNs services like gateway.push.apple.com and feedback.push.apple.com
- Hostname based loadbalancing for BIG-IP under version 11.6.0
- Source address persistence using tables (because when using the node command, persistence settings doesn’t works)
How to use this snippet:
Installation
This irule can be installed on multiple VS at the same time or on a wilcard VS.
During several tests, we configured the following Virtual Server settings :
ltm virtual vs_wildcard_apns {
description *.push.apple.com
destination 192.168.20.200:any
ip-protocol tcp
mask 255.255.255.255
profiles {
fastL4 { }
rules {
irule_apns
source 0.0.0.0/0
source-address-translation {
type automap
translate-address enabled
translate-port disabled
vs-index 9
Code :
when RULE_INIT {
set static::nameserver "8.8.8.8"
set static::max_age 1800
when CLIENT_ACCEPTED {
switch [TCP::local_port] {
"2195" {
set host "gateway.push.apple.com"
"2196" {
set host "feedback.push.apple.com"
default {
log local0. "virtual=[virtual], src=[IP::client_addr], dst=$dest:[TCP::local_port], action=reject, reason=\"Request not allowed\""
reject
return
# resolve the hostname using table or dns lookup
if { [table lookup "$host.[IP::client_addr]"] ne "" } {
set dest [table lookup "$host.[IP::client_addr]"]
log local0. "virtual=[virtual], src=[IP::client_addr], dst=$dest:[TCP::local_port], action=resolve, reason=\"from table\""
node $dest [TCP::local_port]
set dest [lindex [RESOLV::lookup @$static::nameserver -a $host] 0]
log local0. "virtual=[virtual], src=[IP::client_addr], dst=$dest:[TCP::local_port], action=resolve, reason=\"from dns\""
if { $dest ne "" } {
table set "$host.[IP::client_addr]" "$dest" indefinite $static::max_age
log local0. "virtual=[virtual], src=[IP::client_addr], dst=$dest:[TCP::local_port], action=forward"
log local0. "virtual=[virtual], src=[IP::client_addr], dst=$dest:[TCP::local_port], action=reject, reason=\"DNS resolution failed\""
reject
return
when CLIENT_CLOSED {
table delete conn:[IP::client_addr]:[TCP::client_port]
Tested this on version:
11.3
