Hostfix upgrade on F5 LTM
Hello Expert
I have 11.2.1 version. How to know what hotfix I have? I need to apply hotfix 13 on it. Should I download hotfix 13 and apply or I have to download all hotfixes before 13 and apply in a row.
tmsh show sys version
yes
yes
In addition to the tmsh command nitass posted, you can hover with your mouse over the hostname at the very top/left location of the web-gui, that should provide the currently running version as a tooltip. A third way would be to look it up in the web-gui via: System | Software Management | Hotfix List
Means I do not need to download all hotfixes before 13, like HF1,2 and so on? 13 will cover all hotfixes?
yes, hotfix is cumulative.
