we have host sitting inside and refusing http/https connections from outside. we can telnet it from outside (internet) on port 443 bit when we run command https:// then not getting anything and if do telnet then gets connection refused from host.
I have standard virtual server with external vip pointed to inside host ip B.B.B.B
I have SNAT on external VS for outside communication. so flow is like below
telnet A.A.A.A port 80 trying A.A.A.A… connected to A.A.A.A Escape character is ‘^]’ GET /HTTP/1.1
connection closed by foreign host.
Is there anything i am missing on VS setup or any other suggestion ot recommendations please
It’s really hard to help you, if you don’t provide the least of information about your configuration. Could you please add the output of the following tmsh commands:
list ltm virtual
list ltm pool
BTW your HTTP request is not valid (maybe that’s the reason why the BIG-IP denies your request). A correct HTTP/1.1 request use spaces and needs a host header.
GET / HTTP/1.1
Host: www.example.com
An HTTP/1.1 without host header does not comply with RfC and the BIG-IP silently drops or resets those requests.
if yes, you need a ssl client profil and ssl server profil (if your backend listen in ssl/TLS port). you need also http profil in this case.
If no, you don’t need HTTP profil, ssl server or client profil.
Last point if you have a cluster check that your floating IP have access to your backend, because monitoring is done with self IP and you can have a green monitoring and can’t access to your service if you don’t open flow with floating IP as source.
