We have a number of complex test environments that stage from dev through to production. Each environment has LTMs that are all running (theoretically) the same configuration but with different IP addresses in pools, Virtual Servers, iRules etc. The key point is that the hosts in each environment have the same names.
Has anyone managed the configuration in such a large environment by maintaining the bigip.conf file manually with host names and uploading the same bigip.conf file to each LTM with any updates? The /etc/hosts file for the LTM in each test environment is unique to that environment.
I have done a couple of small tests and putting names into bigip.conf directly and then running
b load bigip.conf
works fine - the GUI resolves the names into IP addresses but the bigip.conf file remains with hostnames.
I noticed a strange thing that if you create through the GUI using hostnames they are resolved at that point to IP addresses which then get written to bigip.conf.
any help gratefully received.
cheers, Keith
