Hometab still showing even after unselecting it
I have a portal setup that once you log in you still get the hometab in the top left corner. I have gone into portal access → portal access list and selected teh resource. Unclicked the hometab button in advance and it is still showing up when i log in. Has anyone else had this occur and has a work around.
Wanted to check with the community before i put in a support ticket. Cheers!
The only way that I’ve found to do it is through the advanced customization of the webtop. In the management GUI, you can go to
Access Policy
Customization
Advanced
, the click the
Edit Mode
button and change it to
Advanced
. From there, you can go to
Webtops
[WebtopName]
hometab.inc
. If you scroll down to about line 460 or so, we commented out the
isIe = ...
line and the
var htm_begin
section, and then added the following to hide the hometab altogether.
isIE = false;
var htm_begin = '';
Hope that helps.
