High Speed Logging to SumoLogic Collector not Working
HI,
I am trying to get some values from a HTTP header to be sent to a SumoLogic Collector and am having difficulties with how the messages end up at the SumoLogic box.
I can see the data being sent to the SumoLogic box but it doesn’t seem to be able to read it. The log is just random corrupted text.
I have setup a Log destination as Remote HSL using a pool UDP/1514 and the Publisher set to the Destination config
I have also tried setting up another destination using remote syslog and forward that to the Remote HSL Destination as well but still get same result.
I know this is being sent to the SumoLogic collector because I have got captures going out to the Sumo collector and the UDP Packets contain the text I wanted logged.
Is there some issue on the F5 or is the Sumo collector not reading the format right or something??.
Cheers
I’m not familiar with Sumo Logic, but for my 3 node ELK cluster with 2 logstash servers, I just use HSL. See below.
create ltm node elk1.f5.demo { address 10.1.30.111 description "ELK Logstash/Data/Master Node" }
create ltm node elk2.f5.demo { address 10.1.30.112 description "ELK Kibana/Master Node" }
create ltm node elk3.f5.demo { address 10.1.30.113 description "ELK Logstash/Data/Master Node" }
create ltm pool elk_log_5401_pool { members replace-all-with { elk1.f5.demo:5401 elk3.f5.demo:5401 } }
create sys log-config destination remote-high-speed-log elk_hsl_5401_dest { pool-name elk_log_5401_pool protocol udp distribution balanced }
create sys log-config publisher elk_log_5401_pub destinations replace-all-with { elk_hsl_5401_dest }
