High Speed Logging (HSL:: commands)
I noticed a wiki page for some new commands:
HSL::open
HSL::send
http://devcentral.f5.com/wiki/default.aspx/iRules/hsl
I haven’t heard of these commands or High Speed Logging (protocol?) before. I couldn’t find much online about this.
Can anyone provide some background info on high speed logging and the new commands?
Thanks,
Aaron
Basically we’re sending data to a pool of syslog servers, is that correct? Is it always using port 514 (syslog)?
Is the data broadcasted to all member in the pool?
Thanks for the info Colin.
So it’s still using standard TCP or UDP syslog. Is there any difference in performance between using log -remote versus HSL? Is there a reason you have to call HSL::open before using HSL::send? If there isn’t an HSL::close, couldn’t the open command be inferred with an HSL::send?
Aaron
Actually, can you just answer the performance question? I figured out from the HSL::open wiki page that you specify the log protocol and destination pool of syslog servers.
Thanks,
Aaron
There shouldn’t be any performance difference as it’s using the same send mechanism, as I understand it. They’ve just made that mechanism more easily accessible for things outside a standard syslog message. So say you want to save off the HTTP request that got sent to your server but looked suspicious, well, now you could use HSL to dump that off to a system listening for that data, etc.
Colin
Can someone provide any documentation or examples of creating the syslog_pool?
Thanks,
Dan
Hi Dan,
That should just be a standard LTM pool, I’d guess.
b pool my_syslog_pool {members 1.1.1.1:514}; b save
would create the pool from the command line and save the config from memory to file.
Aaron
Hi -
I finally got to upgrade to 10.1.0 today so I could work with HSL. I got my iRule converted to use teh HSL::open and HSL::send commands. What surprised me is the change in the log format from the log command. What I get with HSL::send is a continuous string in my log file with no time stamps and no line feeds. That makes parsing the log file for analysis impossible.
I have been looking for more information on HSL but have not found much to help.
Here is my original iRule:
Get time for start of HTTP request
set http_request_time [clock clicks -milliseconds]
HTTP::collect 4096
Log the start of a new HTTP request
set LogString “[IP::client_addr] [HTTP::host] [HTTP::method] [HTTP::uri]”
log 192.168.50.17 local0.info “$LogString”
when HTTP_RESPONSE {
Received the response headers from the server. Log the pool name, IP and port, status and time delta
log 192.168.50.17 local0.info “$LogString [HTTP::status] pool_info: [LB::server] (ResponseTime: [expr [clock clicks -milliseconds] - $http_request_time]ms)”
Here is what i see in syslog
Mar 9 16:22:12 rn-f5-lan-sip-01 tmm1[6906]: Rule WebLog : 173.70.45.182 ev.ib-ibi.com GET /image.ibvx?sessionid=6e61cafe-01ba-4fb7-af26-c574ccc24c36&go=iblx&osid=aac88b74-68f7-4b05-81b2-dba5cce0b6b2&puburl=http%3A//isabellacatalog.com/&advurl=http%3A//www.isabellacatalog.com/cat.cfm/pgc/21300/sbc/21306
Mar 9 16:22:12 rn-f5-lan-sip-01 tmm1[6906]: Rule WebLog : 173.70.45.182 ev.ib-ibi.com GET /image.ibvx?sessionid=6e61cafe-01ba-4fb7-af26-c574ccc24c36&go=iblx&osid=aac88b74-68f7-4b05-81b2-dba5cce0b6b2&puburl=http%3A//isabellacatalog.com/&advurl=http%3A//www.isabellacatalog.com/cat.cfm/pgc/21300/sbc/21306 200 pool_info: Prod-443 192.168.50.14 443 (ResponseTime: 1ms)
Here is my HSL irule:
set hsl [HSL::open -proto TCP -pool rn_syslog_server_pool_01]
HTTP::collect 4096
HSL::send $hsl “$LogString”
HSL::send $hsl “$LogString [HTTP::status] pool_info: [LB::server] (ResponseTime: [expr [clock clicks -milliseconds] - $http_request_time]ms)”
204.128.27.8 ev.ib-ibi.com GET /at.js?sessionid=9c547e54-f657-4b5f-8069-0789c6bb6aa8&go=122&osid=dcd5a534-39af-44e1-9ad8-2580a7375d59204.128.27.8 ev.ib-ibi.com GET /at.js?sessionid=9c547e54-f657-4b5f-8069-0789c6bb6aa8&go=122&osid=dcd5a534-39af-44e1-9ad8-2580a7375d59 200 pool_info: Prod-443 192.168.50.21 443 (ResponseTime: 24ms)70.181.136.166 ev.ib-ibi.com GET /at.js?sessionid=232af8d3-4bd4-4795-9d97-342a368eaf17&go=126&osid=8a7e4586-8d65-4e38-b535-89ff4f5afd4370.181.136.166 ev.ib-ibi.com GET /at.js?sessionid=232af8d3-4bd4-4795-9d97-342a368eaf17&go=126&osid=8a7e4586-8d65-4e38-b535-89ff4f5afd43 200 pool_info: Prod-443 192.168.50.13 443 (ResponseTime: 13ms)75.111.39.162 ev.ib-ibi.com GET /lat.js?sessionid=b4d4c59c-fc21-43ff-b6fd-0afcc9744dcf&go=&osid=fc2af33e-6223-4de8-a101-b4e6faaa288675.111.39.162 ev.ib-ibi.com GET /lat.js?sessionid=b4d4c59c-fc21-43ff-b6fd-0afcc9744dcf&go=&osid=fc2af33e-6223-4de8-a101-b4e6faaa2886 200 pool_info: Prod-443 192.168.50.14 443 (ResponseTime: 4ms)170.213.132.253 ev.ib-ibi.com GET /at.js?sessionid=43abdb4c-b356-495c-8967-4c41c68a19c3&go=125&osid=0aae746c-2dc7-49f3-af94-aba96ba850d7170.213.132.253 ev.ib-ibi.com GET /image.ibvx?sessionid=43abdb4c-b356-495c-8967-4c41c68a19c3&go=125&osid=0aae746c-2dc7-49f3-af94-aba96ba850d7&puburl=http%3A//ad.yieldmanager.com/st%3Fad_type%3Diframe%26ad_size%3D160x600%26section%3D816134&advurl=http%3A//ad.yieldmanager.com/iframe3%3FZiAAAAZ0DAB5CEMAAAAAABjIEQAAAAAAAAAEAAoAAAAAAAsAAwADEJwjFwAAAAAAmpEYAAAAAAA
Mar 9 16:02:53 rn-f5-lan-sip-01 .4.60: ev.ib-ibi.com GET /at.js?sessionid=1e018768-5847-4712-aaf6-98f420697ff9&go=115&osid=0ebe8305-86a6-46c9-b2d5-e7e23ef737b2209.188.179.1 ev.ib-ibi.com GET /at.js?sessionid=68e5ed77-3f0a-4223-bcb3-6fbb07de1f4c&go=125&osid=1b17cdca-9085-414f-ae9b-b127d43c0053 200 pool_info: Prod-443 192.168.50.13 443 (ResponseTime: 25ms)208.54.4.60 ev.ib-ibi.com GET /at.js?sessionid=1e018768-5847-4712-aaf6-98f420697ff9&go=115&osid=0ebe8305-86a6-46c9-b2d5-e7e23ef737b2 200 pool_info: Prod-443 192.168.50.14 443 (ResponseTime: 14ms)71.207.153.35 ev.ib-ibi.com GET /at.js?sessionid=334fc6c3-4f78-47cd-9324-cffdf71c37ac&go=125&osid=a75b1403-771d-49ce-8bdb-65a9cd30274b71.207.153.35 ev.ib-ibi.com GET /at.js?sessionid=334fc6c3-4f78-47cd-9324-cffdf71c37ac&go=125&osid=a75b1403-771d-49ce-8bdb-65a9cd30274b 200 pool_info: Prod-443 192.168.50.15 443 (ResponseTime: 14ms)
Any help would be greatly appreciated
Dan
Thanks for the additional info, Spark.
Could multiple connections reference the same HSL handle (ie, save the HSL::open handle to a global variable)? Or would that defeat the purpose?
Also, when the HSL::send wiki page states “…that a specific pool member cannot be specified. Pool members are selected based on an internal algorithm.”, does this mean that the syslog message is sent to one pool member or broadcast to all pool members?
Thanks,
Aaron
I don’t see any problem with multiple connections using the same handle. It definitely doesn’t defeat the purpose.
The message is sent to one pool member only. The point of that sentence is that you can’t directly specify or control which pool member gets a specific message. I should update that Wiki page; it’s not “an internal algorithm”, exactly, it’s the LB method that is specified in the pool.
Do you know of a way to enter a line feed in a iRule? Specifically I want to put a line feed after each of these entries
thank you!
Sorry it took so long. I just noticed this question…
HSL::send $hsl “$LogString [HTTP::status] pool_info: [LB::server] (ResponseTime: [expr [clock clicks -milliseconds] - $http_request_time]ms)\n”
Notice the \n in the string… Standard unix EOL character… (LineFeed)
H
The examples show the HSL::open command being run in the CLIENT_ACCEPTED event. So, will every new connection grab a new handle for HSL logging? Could the HSL::open command go inside RULE_INIT, and if so, is it likely to improve performance?
I’m just trying to figure out if the LTM could “run out” of available handles for HSL under load.
thanks for any reply
How and where do we apply this iRule, have a confusion about this. I am trying to setup a remote syslog server and dont want any of the logs collected locally on the F5 device, LTM in this case. How to set this up.Please help me with this.
You would create an iRule which initiates the HSL connection and sends messages to the pool. You’d then associate the iRule with any virtual server which you want the iRule to run on.
Aaron
SYSLOG-NG.CONF file
I need help in understanding the functionality of the syslog-ng.conf file in the folder /etc/syslog-ng. Can any of you kindly direct me to the document which explains this file in detail. I see that this file when tweaked can help determine the logging, just want to understand the way it functions. Thanks for any help will be much appreciated. Thanks
sprashanthac
the HSL is not based on syslog-ng. it is basic TCP/UDP.
syslog-ng, if you wish to use that, is a not an F5 feature - you should be able to google it.
Yeah right , think this question should be posted on the syslog-ng section not in the HSL one
As Simon said, the syslog-ng configuration is standard. You can look up the available options for your specific version (retrieved by running syslog-ng -V on the unit) on these sites:
http://www.syslog.org/syslog-ng/v2/
http://www.balabit.com/support/documentation
http://www.balabit.com/support/documentation/syslog-ng-v2.0-guide-admin-en.pdf
One significant difference with using syslog-ng on the LTM platform is that you need to modify the syslog-ng configuration that LTM loads using the bigip_sys.conf or bpsh utility. Deb wrote a great article on this:
LTM 9.4.2+: Custom Syslog Configuration
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=155
Aaron
Posted By sirwin on 06/08/2010 09:10 AM
I was informed that there isn’t actually any gain in trying to use a shared handle for HSL as HSL internally caches and garbage-collects message queues and connections.
Aaron
