High Packet Drop and connection failure
Have a pair of LTM 1600 (named LTM1 & LTM2) and a pair of cisco2960 (2960-1 2960-2) whereby the detailed connection are as below:-
LTM1 internal-trunk = interface 1.3 + 1.4
LTM1 internal-trunk (LACP Enabled, LACP Mode=Active, LACP Timeout = Long, Link Selection Policy = Auto, Frame Distribution Hash=Src/Dst IP)
LTM1 fibre = interface 2.1 + 2.2
LTM1 VLAN External (Tag=10, Untagged Interface=1.1)
LTM1 VLAN Internal (Tag=4093, Untagged Interface=internal-trunk)
LTM1 VLAN pri-failover (tag=4092, Untagged Interface=Fibre)
LTM1 interface 1.1 → uplink cisco
LTM1 internal-trunk → 2960-1 port channel 3
LTM1 Fibre → LTM2 Fibre
LTM2 with exactly the same configuration
2960-1 port channel 5 → 2960-2 port channel 5
Please find below show run cutting relevant information :-
2960-1show run
Building configuration…
Current configuration : 6188 bytes
version 12.2
hostname 2960-1
no ip source-route
no ip domain-lookup
vtp domain f5-private
vtp mode transparent
spanning-tree mode pvst
spanning-tree extend system-id
port-channel load-balance src-dst-ip
vlan internal allocation policy ascending
vlan 4093
name f5-private-vlan
interface Port-channel3
switchport access vlan 4093
switchport mode access
no keepalive
flowcontrol receive desired
interface Port-channel5
interface GigabitEthernet1/0/1
no keepalive
no cdp enable
no cdp tlv server-location
no cdp tlv app
spanning-tree portfast disable
channel-group 3 mode active
interface GigabitEthernet1/0/2
no keepalive
no cdp enable
no cdp tlv app
interface GigabitEthernet1/0/3
channel-group 5 mode desirable non-silent
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
shutdown
interface Vlan4093
ip address 192.168.1.1 255.255.255.0
ip sla enable reaction-alerts
no cdp run
end
2960-2 with exactly the same configuration. The detailed situation is that it seems to have high connection failure rate from external subnet to virtual server. I have done a flood ping from 2960-1 to LTM1 without problem vice versa, but I have observed that there are around 10% packet drop when I tried to ping from LTM1 to LTM2 using either internal IP or external IP. Have reached the same result (10% packet drop) when I tried to ping from any host sitting in the internal subnet of LTM to LTM1/LTM2 using either internal or external IP. But I can reach 0 packet drop when I ping from host to 2960-1/2960-2 or vice versa. Is this caused by mis-configuration? How can I troubleshoot this?
do you know whether it affects application traffic (i.e. client to virtual server)? if yes, have you captured packet when problem is happening?
sol10191: Troubleshooting packet drops
Yes, it is affecting traffic whereby there are some connection going from external Host to the Virtual Server failed. Have captured the traffic and am analyzing the traffic now. But the traffic volume is huge and it is really quite difficult and takes much time. Therefore, I would like to start from the basic which is to first ensure the cisco switch as well as the LTM configuration is right.
In addition, when I show interface and I found that the cisco etherchannel side have a lot of packet drop (over 10k for 1 week), does it means there must have some kind of problem between the connection of this two unit?
The 2910-1 to LTM tests pretty much verifies the hardware/cabling is good. Let’s dig deeper for an app or utiliization issue.
1) When you issue a “sh int” on the Cisco switch, is the negotiated line speed/duplex correct?
2) Have you polled the bigip interfaces with a mgmt/snmp tool to check utiliziation? Or what is the utilization on the Cisco port side?
3) The 1600 is only rated at 1gb. Marketing aside, the advertised rate for ANY vendor means total throughput. That is 1gb total process of traffic inbound and outbound simultaneously. Let’s verify 2.
4) I’m not worred about the drops if iti is a busy network. Any mutlicast traffic such as lldp, cdp, stp, etc will be dropped unless the box is configured for it, which it isn’t.
5) when looking at the captures… are there a lot of resets? Look for the longest Delta times and get a feel for what is going on.
6) Have you added any new iRules lately?
8) Are there errors on the ports (cisco or bigip)?
7) Why do you need this command on the switch - " flowcontrol receive desired"? You really need to know your environment if you start messing flow control, especially on gig links. I always leave everything to auto on both ends.
8) What LB algorith are you using on the pool?
I would take a capture but only on the most problematic VS and attempt to capture what is happening on the external and internal at the same time. Just run two tcpdumps, one for each vlan.
Thx Macro for your quick reply. I also think the the direct ping between LTM and 2960 shows that the network cable is good at least and there are some other issues with that. Lets see my answer below:-
1. The dupex and line speed are 1000 full on both end which is matched.
2. From what I can see, the network utilization is not high. I don’t have mrtg graph but just to get a test using sh int as well as using the dashboard of F5 only.
3. see 2
4. I have already turned off cdp on the port in order to reduce the packet drop and actually cdp is not useful for port connecting F5 either. The reason behind turning off CDP is that, I would like to reduce the no of packet drop down to zero which is required by our management team so is there any configuration in the cisco end that I can enable/disable in order to further reduce the packet drop due to unused feature or traffic?
5. Still scratching my head and pulling my hair with the capture, coz it is in terms of tens of mega bytes. Will start with TCP reset. Any other hints for me?
6. No. Not actually using any iRules.
7. There are no errors on the cisco etherchannel, just packet drop. In higip, how can I obtain the interface errors?
8. Actually I have been fighting for the packet drop for long and found article saying that the flowcontrol is not working very well between cisco and big-ip with the auto setting. Anyway, can try to switch it back to auto if that would really help.
9. The LB algorithm is simply round robin but I think it is not related. Coz I have packet drop even simply pinging to the node drirectly from external subnet.
I have done a capture on both interface (as well as on the node and the external host), therefore I am now checking four * tens of mega bytes capture. The size is huge bcoz the connection is really quite intermittent. I can successfully establish a connection with the node very often but not always. Thats why I have to capture the traffic for a bit long in order to ensure that there must of at least one failure connection within the capture.
1. The duplex and line speed are 1000 full on both end which is matched.
3. see 2
4) Take a capture and put it into wireshark. filter for all broadcast and multicast. From there we can get an idea of any harmful drops. Bursty traffic could overflow the buffers but you stated earlier that direct pings were fine. Did you do extended pings as well with a larger payload?
5) TCP Resets and look for long Delta times in wireshark. Isolate that conversation and compare the external and internal captures to see if a particular server is taking a long time to respond. You could also use AVR, fidderl or httpwatch to hit the most problematic VS and attempt to locate a particular URL/uri combo that is taking long time to complete.
7) In the gui, Network → Interface or cli:
[root@ltm1:Active:Disconnected] config tmsh show /net interface
Net::Interface
Name Status Bits Bits Pkts Pkts Drops Errs Media
In Out In Out
1.1 up 118.1M 8.8K 137.9K 19 0 0 none
1.2 up 62.8M 10.5K 23.0K 24 0 0 none
1.3 up 90.7M 19.1M 80.8K 57.0K 0 0 none
mgmt up 9.6M 7.3M 8.2K 5.6K 0 0 100TX-FD
9) a) If a particular server gets busy, RR will keep hammering it. I use Observed Member as my Best Practice. It will monitor server repsonse times (amongst other things) to determine when to back off of a server, giving it time to catch up.
b) When you say “pinging to the node”, what node? LTM VS? If so, that ping does NOT make it to the pool member. If you are having trouble here, then I tend to look back at the network/cabling again.
10) Is the specific VS a 3-tier app? Are there database calls being made by the web or middleware that the webserver/client would need to wait on.
11) If you can find a time when you failed to make a connection to the VS (node in your terms?) and you have front and back captures, you will most likely have caught the main portion of your problem or at least the biggest clue. I would keep a continuous ping going as well to see what happens at the same a failed attempt occurs.
4. I have do a flood ping with results below:-
No packet drop:-
2960-1 <> LTM1
2960-2 <> LTM2
Around 10% packet drop:-
LTM1 <> LTM2
LTM1 <> Any Node sitting under 2960-1
LTM2 <> Any Node sitting under 2960-2
normal ping with packet size 1000 and 10000 to and from anywhere doesn’t have any problem at all
To give a more concrete picture, please find below a brief network diagram
2960-3 ------------------------- 2960-4
LTM-1 ============= LTM-2
2960-1 ============ 2960-2
NODE-1…
Connection List
2960-3 <> LTM-1 Normal single UTP
2960-4 <> LTM-2 Normal single UTP
LTM-1 <> LTM-2 Fibre dual link
LTM-1 <> 2960-1, LTM-2 <> 2960-2 Dual UTP with etherchannel (LACP src/dst IP)
2960-1 <> 2960-2 Dual UTP with etherchannel (PAGP)
All Node connect to both 2960-1 and 2960-2 with active-standby bonding and both LTM is also running in active-standby mode.
Can I ask a simple question is the above configuration works? Anything else I have to check? I can get rid of the LACP and PAGP if dual link is not really necessary (between LTM and 2960 as well as in between two 2960), coz I have overlook that the throughput of 1600 is barely 1GHz and dual links seems not really necessary, right? What about VTP? Should I round VTP in transparent mode? One last question is the STP, coz from the LTM STP interface I found that there is one STP setting with Bridge Priority 61440, does it need to be a match in Cisco? How can I check and fix if needed?
5. Will double check. Recently we found a lot of SMTP request connection failure, will try to focus on port 25.
7. Drop rate is high but error is zero.
9. a) I wonder if this problem is not related to VS coz simply pinging from LTM-1 to LTM-2 also have problem.
b) But pinging from cisco to the immediate connected F5 or node doesn’t yeild any problem and thus I guess it is not related to cabling problem, am I guess correct?
10. Up to now, we can only find that a lot of smtp connection problem and the smtp server is rather powerful and guess that it is not related.
11. Will try to check out the tcpdump with wireshark but it is really difficult.
since smtp connection is affected, i think it may be easier to investigate it (e.g. tcpdump on bigip and see if packet arrives at bigip or whether packet is dropped by bigip).
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x or host y.y.y.y or host z.z.z.z and port 25
x.x.x.x is virtual server ip
y.y.y.y/z.z.z.z is pool member ip
just my 2 cents.
See notes inband and below"
LTM-1 <> LTM-2 Fibre dual link -->> Does this fiber directly connect the two units or are they going through a switch? (HA subnet?)
In regard to these tests:
Around 10% packet drop:- --> very high but there may be something we are missing here.
LTM1 <> LTM2 --> Is this a direct fiber cable between each unit or are they going through the switch?
LTM1 <> Any Node sitting under 2960-1 --> Are you routing to the node or is the LTM directly on the same subnet (single leg or 802.1q)?
LTM2 <> Any Node sitting under 2960-2 → Is this ping taking place over an HA subnet or internal vlan subnet from self-ip to self-ip?
There is no need to get rid of the channel configuration. This gives you physical layer redundancy. Temporarily though, it wouldn’t hurt to just pull one cable from each channel to simplify the infrastructure. Singe links temporarily. VTP shouldn’t have anything to do with this, although I have never been a big fan of it and always left it in transparent mode, but that’s another discussion. The default for STP is passthrough although I usually disable it. Don’t let my so-called best practices sway you, everyone has an opinion on it.
Leave the bridge id alone. It’s just set high to keep it from becoming root. It shouldn’t “match” anything unless you really know what you are doing. You’re other assumptions are correct (9, 10).
As Nitass stated and as said before, let’s focus on the problematic VS. In this case you mentioned the smtp vs. Take front and back dumps simultaneously and attempt to catch/find a “broken” connection. From there, we can analyze further.
Also, have you tried failing the LTMs over in case one is acting up?
LTM-1 <> LTM-2 Fibre link directly attached without going over any SAN switch.
Ping from LTM-1 to LTM-2 actually goes thru the path LTM-1 (LACP) → 2960-1 (PAGP) → 2960-2 (LACP) → LTM-2
Ping from LTM-1 to any node sitting under 2960-1 is actually using the same F5 subnet (subnet where the internal interface belongs).
Ping from LTM-2 to any node sitting under 2960-1 is actually using the same F5 subnet (subnet where the internal interface belongs).
Have performed tcpdump on F5 internal interface, F5 external interface, the Node as well as the client and found that there are actually quite a lot of TCP RST sent from the client. It is really strange, coz to perform this test, I have written one simple telnet script something like:-
telnet smtpserver 25 << EOF
QUIT
EOF
Any reason why the tcpdump show us the TCP connection being reset by client with this simple script? Seems like the TCP RST is being sent from the network layer instead but I really don’t know why.
For we have tried to fail over from LTM-1 to LTM-2 but have not performed the tcpcapture nor doing any ping test. Would that give more information?
These types of problems are always like going down the rabbit hole, especially over a medium like this. It does look like we are starting to narrow it down.
The LTM1 <> LTM2 ping loss is worth looking into, but not yet. I would be more concerned about losing pins from LTM1/LTM2 to any node under the 2960. I want you to find a node that is actually plugged into 2960-1. This is important. We don’t want that traffic going across the PAgP link. I then want you to perform two ping tests. One with a 1000 and one with 10000 pings issued from LTM to the internal/inside node that is plugged into 2960-1 physically. Please report back.
If you are getting TCP RSTs from the client, then you need to dig further into this. This is the clue we have been looking for. Please verify the RST is from the client first. Make sure there isn’t one from the server beforehand and also verify what communication took place right before the RST. Sample a couple of RSTs to see if it is the same call causing this. Focus in using the tcp.port or udp.port filter in wireshark.
The client is probably sending TCP RSTs because you’re not doing anything and you ending the session (QUIT command). Sounds like normal behavior to me.
BTW, what version are you running again? 10.2?
The client is probably sending TCP RSTs because you’re not doing anything and you ending the session (QUIT command). Sounds like normal behavior to me. it does send FIN here. since QUIT is sent right after connect, i do not think client should send RST.
just my 2 cents.
Nitass, In my experience of going through app traces for years, I have seen that at least half of all apps don’t end sessions cleanly. You don’t get the 4-way tcp closure very often, not like you would expect. I see Resets being very common and it’s often messy for both sides of the connection.
If this particular conversation of the trace could be posted here, that would help. You could export it to text and the substitute the ip addresses with anonymous ones.
In my experience of going through app traces for years, I have seen that at least half of all apps don’t end sessions cleanly. You don’t get the 4-way tcp closure very often, not like you would expect. I see Resets being very common and it’s often messy for both sides of the connection.i see. thanks :slightly_smiling_face:
If this particular conversation of the trace could be posted here, that would help. You could export it to text and the substitute the ip addresses with anonymous ones.this is what i tested here.
virtual server
[root@ve11a:Active:Changes Pending] config  tmsh list ltm virtual bar
ltm virtual bar {
    destination 172.28.20.111:25
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        tcp { }
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 6
 client
[root@centos17 ~] telnet 172.28.20.111 25
Trying 172.28.20.111...
Connected to 172.28.20.111 (172.28.20.111).
Escape character is '^]'.
220 ESMTP
quit
221
Connection closed by foreign host.
 packet trace
[root@ve11a:Active:Changes Pending] config  tcpdump -nni 0.0 host 172.28.20.111 and port 25
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes
23:36:36.489354 IP 172.28.20.17.55215 > 172.28.20.111.25: S 2510838242:2510838242(0) win 5840
23:36:36.489397 IP 172.28.20.111.25 > 172.28.20.17.55215: S 485573986:485573986(0) ack 2510838243 win 4380
23:36:36.490487 IP 172.28.20.17.55215 > 172.28.20.111.25: . ack 1 win 5840
23:36:36.874546 IP 172.28.20.111.25 > 172.28.20.17.55215: P 1:24(23) ack 1 win 4380
23:36:36.876531 IP 172.28.20.17.55215 > 172.28.20.111.25: . ack 24 win 5840
23:36:37.921334 IP 172.28.20.17.55215 > 172.28.20.111.25: P 1:7(6) ack 24 win 5840
23:36:37.921360 IP 172.28.20.111.25 > 172.28.20.17.55215: . ack 7 win 4386
23:36:38.111502 IP 172.28.20.111.25 > 172.28.20.17.55215: P 24:41(17) ack 7 win 4386
23:36:38.111515 IP 172.28.20.111.25 > 172.28.20.17.55215: F 41:41(0) ack 7 win 4386
23:36:38.112569 IP 172.28.20.17.55215 > 172.28.20.111.25: . ack 41 win 5840
23:36:38.112573 IP 172.28.20.17.55215 > 172.28.20.111.25: F 7:7(0) ack 42 win 5840
23:36:38.112586 IP 172.28.20.111.25 > 172.28.20.17.55215: . ack 8 win 4386
Frank,
I think we are at a stalemate here. Yes, retransmissions are normal. Resets are common but not a good thing (most of the time). Nitass is right also. You shouldn’t get a reset, of course. I just don’t want you get hung up on it. It’s just a clue (symptom) to uncovering the issue.
Items:
1) These simple tests may not be enough. It is not the same as your production traffic. Just sending a hello and/or just a quit isn’t much. Where’s the mail to and from? Smtp doesn’t really have that many commands but it’s the one’s your missing in your tests that could be causing the problem. Perhaps there is an authentication issue (if required)? Perhaps a username isn’t being recognized. ??? Maybe an unsupported command is coming across. ??
2) I don’t know why telnet causes the resets for you. It is probably due to the buffer and the EOF all being pushed down the pipe. I know EOF is just to let the shell know the input is ended but it all gets put into the buffer and it makes a difference in the trace. I]m wondering if the QUIT is getting there before the 220 comes back. It works itself out but it makes the order of the packets look a bit strange. I have attached two wireshark images (taken from LTM tcpudmps). The one called smtp_without_eof.png and is a simple connect and QUIT without using EOF. The second image is called smtpeof.png and is when I used EOF like you did. Notice how it throws off the decodes in wireshark. I get weird results sometimes when replicating http monitors using telnet. There’s no reason to put more cycles int this, at this time.
3) Did you compare your telnet session to a legitimate connection using tcpdump/wireshark? Let’s focus on getting the right captures at this point. Just take captures from the front and back and then focus on the resets or long delta times for starters. Let’s see if the same type of connections/users causing the resets or if it is load. You can also open a case and they will help you parse through the captures.
4) Did you test to both/all of your smtp servers directly or were you hitting the vip everytime? Are you using persistence? I also assume you are running these tests/scripts from the LTM.
When reply back regarding 3, we can examine it further.
Finally, we found happened. It is because the Pool do not have session persistence set. We have changed the persistence profile to source address and the issues is solved. Thx everyone for help.
