I have 26 CPUs in multi thread format but only CPU 0 utilization goes 100 and other CPUs utilization remains under 30%.
# tmsh show /sys tmm-info
Sys::TMM: 0.0
Global
TMM Process Id 15246
Running TMM Id 0
TMM Count 1
CPU Id 0
Memory (bytes)
Total 29.6G
Used 4.7G
CPU Usage Ratio (%)
Last 5 Seconds 100
Last 1 Minute 100
Last 5 Minutes 100
Sys::TMM: 0.2
Global
Running TMM Id 2
TMM Count 1
CPU Id 2
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 25
Last 1 Minute 25
Last 5 Minutes 25
Sys::TMM: 0.4
Global
Running TMM Id 4
TMM Count 1
CPU Id 4
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 22
Last 1 Minute 22
Last 5 Minutes 22
Sys::TMM: 0.6
Global
Running TMM Id 6
TMM Count 1
CPU Id 6
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 30
Last 1 Minute 28
Last 5 Minutes 28
Sys::TMM: 0.8
Global
Running TMM Id 8
TMM Count 1
CPU Id 8
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 21
Last 1 Minute 21
Last 5 Minutes 21
Sys::TMM: 0.10
Global
Running TMM Id 10
TMM Count 1
CPU Id 10
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 62
Last 1 Minute 62
Last 5 Minutes 62
Sys::TMM: 0.12
Global
Running TMM Id 12
TMM Count 1
CPU Id 12
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 23
Last 1 Minute 21
Last 5 Minutes 22
Sys::TMM: 0.14
Global
Running TMM Id 14
TMM Count 1
CPU Id 14
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 22
Last 1 Minute 21
Last 5 Minutes 21
Sys::TMM: 0.16
Global
Running TMM Id 16
TMM Count 1
CPU Id 16
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 24
Last 1 Minute 24
Last 5 Minutes 25
Sys::TMM: 0.18
Global
Running TMM Id 18
TMM Count 1
CPU Id 18
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 22
Last 1 Minute 21
Last 5 Minutes 22
Sys::TMM: 0.20
Global
Running TMM Id 20
TMM Count 1
CPU Id 20
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 24
Last 1 Minute 22
Last 5 Minutes 22
Sys::TMM: 0.22
Global
Running TMM Id 22
TMM Count 1
CPU Id 22
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 21
Last 1 Minute 20
Last 5 Minutes 20
Sys::TMM: 0.24
Global
Running TMM Id 24
TMM Count 1
CPU Id 24
Memory (bytes)
Total 0
Used 0
CPU Usage Ratio (%)
Last 5 Seconds 22
Last 1 Minute 21
Last 5 Minutes 21
- If you define the correct DAG , you shouldn’t see that one of TMM instances CPU is 100 % , Correct DAG value protects your from Context-swiching ( which means one of your TMM is 100% so it couldn’t handle the data traffic for clients so this leads to redirect connrctions to another TMM or drop it , also if TMM is fully utilized it may request more resources to handle this high pressure on it whereas the other TMMs not handle this quantity of data traffic )
This is from my perspective , but I want to know the updates till reach the optimal value of TMM CPU maybe I am not fully correct, so I will keep the attention for this thread here
As @Mohamed_Ahmed_Kansoh mentioned check the TMM outside of that in older versions the CMP demoded VS caused such issues but we do not know your version myF5 / myF5 and this something F5 ihealth can show you.
As CPU is even number it means this core is for data plane as seen in the article here, so checking the TMM is good step: myF5 / myF5
As I don’t see errors in passing traffic and somehow balanced traffic for all TMM instances ( maybe only TMM0.10 handles high connections so it’s CPU is +60% ) but over all TMMs CPU is within 20%.
So this is an indication of that TMM0 represents the Total CPU & memory usage in your blade and because you have till 24 tmm instances it gave you 100 % as this is a high number of TMMs.
This is Clarified in this Article : https://my.f5.com/manage/s/article/K02895424
Now , you should keen on in the overall CPU & memory usage as average between all TMMs cores.
If you go to ( Statistics >>> Performance reports >>> Chech the CPU & memory graphs )
Also adjust time range ( Last 3 hours then Last week , then last month )
I’m sure you will find the overall Cpu is consistent following the same trend for all other graphs , I mean you will find the overall/average CPU for the ( last month/week/day/hours ) not high or reached to 100%
Do u know if you found this overall CPU reached to 100 % your box will failover immediately.
So I need you to check that performance report and let me know if my analysis is correct or not.
