Would like to ask for possible cause and fix. We have high CPU utlization on CPU1 . It seems it is the systems causing our CPU1 high utilization. Our F5 is in Virtual and in version 12.1.2. Thank you!
CPU: 0 (clock ticks) Last 5 sec Last 1 min Last 5 min Total
- (avg/sec) (avg/sec) (avg/sec) -
User 8 3 2 26.7M
Niced 0 0 0 3.9M
System 58 13 3 17.3M
Idle 33 83 94 2.7G
Irq 0 0 0 8.5K
Softirq 0 0 0 2.0M
Iowait 0 0 0 2.0M
Stolen 0 0 0 0
Util% (last 10 sec) - - - 0
CPU: 1 (clock ticks) Last 5 sec Last 1 min Last 5 min Total
User 5 2 1 28.3M
Niced 0 0 0 6.5M
System 30 4 1 45.6M
Idle 63 94 97 2.7G
Irq 0 0 0 582
Softirq 0 0 0 501.0K
Iowait 0 0 0 2.5M
Stolen 0 0 0 0
Util% (last 10 sec) - - - 100
It’s a centos (i.e. RedHat) base. (Not sure which one for 12.1.2 - But my v24 uses Centos 6.8).
However it shouldn’t normally use a lot of CPU. Anything logged? (/var/adm/messages) or in the ‘dmesg’ output?
Have you edited inittab at all? Normally there’s just a single entry in there, but some people (Myself also) like to put important daemons in there with restart enabled. Breaking those can cause init to spin.
I take it from the discrepenecy between your tmmsh cpu output and top that it’s bursty?
Any system where the console is not hooked up to /dev/sttyS0 (such as all virtual editions) and where the above bug is not fixed, can experience just high disk usage, not CPU.
However, in your case I can see that CPU1 high cpu is caused by system usage and you confirmed that init is eating up cpu cycles so I’d try changing the “respawn” to “off” in /etc/init/serial-ttySX.conf and rebooting the box (make it standby first!)
I also see a specific monitor (iweb-serviceadmin_new-4435) going up and down. It would be good to have a look at what is causing it too or at least temporarily disabling it just in case.
